-   -   Air conditioner starts from defrost then switches to dash vents (https://www.mercuryforum.com/forum/grand-marquis-14/air-conditioner-starts-defrost-then-switches-dash-vents-6098/)
rbl_at_home Jun 13, 2012 11:24 AM
My Mercury 2004 GS with ETC Air conditioning starts from defrost then switches to dash vents.
Is the a way to reset the ETC to factory defaults?
Thanks in Advance
Russ
91GrandMarquisGT Jun 13, 2012 03:49 PM
Usually when a HVAC system goes to defrost there is a lack of vacuum to operate the right mode. Defrost is the default when the vacuum source is gone. The blend doors, and mode doors are operated by engine vacuum. Start with checking the feed from the engine to the HVAC box. Then pull the Climate control head and ck for vacuum there. The head could also be bad. Not sending the vacuum to the right place quick enough.
rbl_at_home Jun 15, 2012 02:44 PM
I do not believe it is the Vacuum. All of the other settings, except vent work OK
AZFastDan Jun 27, 2012 01:10 PM
For safety reasons the default position is defrost on. If/when the system operates correctly it changes to a/c. If it stays on defrost, then you have an issue.
TrentMassey Jul 25, 2012 02:23 AM
KelleyHoward Aug 23, 2012 03:13 AM
Criminal Minds Season 7 DVD
Once Upon a Time Season 1 DVD
