-   -   Air suspension (https://www.mercuryforum.com/forum/grand-marquis-14/air-suspension-3211/)
Devil Boy Aug 17, 2009 04:07 PM
Air suspension
Hi all, I have a problem with my MGM 04 Ultimate Edition
the car is a little bit lower from the left side comparing with the right side.
I've been told that is there is a problem with the air suspension, the light in the electronic gauge will light up, but it didn't!
Is the problem form the air balloons or what?
slymer Aug 17, 2009 04:18 PM
check your fuses first off. if the fuse for the air system is blown, you have an issue in the system that needs to be addressed (something is shorted). I'm not real up on the air suspensions, but from my limited understanding, if things aren't level, there may be some stuck valves or cracked hoses (leaks somewhere) Considering the age (not that old) it should be cracks in the rubber, but rather sticky valves or possibly blown check valves if there are any. There should be someone else on here that knows more about the air setups that can be more informative.
