I need some HELP! I have a 2003 Grand Marquis, the air conditioner works however, my fan will not blow the air. The fan icon shows up when I turn on the fan but nothing happens. Any suggestions before I pull out the fan? Thanks |
Does the fan work at any speed for any setting? e.g. heat, vent, defroster.
No. The fan does work if I connect it straight to the battery. The indications on the climate controls are:when I first select the air, heat, whatever the auto indication is displayed but there is zero air movement. When I attempt to manually select a fan speed the auto indication goes away and the fan icon is displayed but the fan does not turn on or display any indication of the fan speed. Thanks |
you probably need a fan speed switch. some have two. a low speed and a high speed fan switch.
