Brakes OUT
Old Feb 1, 2013 | 01:11 PM
Byron McClure's Avatar
Default Brakes OUT
1996 mercury grand marquis.
under the dash there is a spring loaded switch that works my rear brakes. when i push on it. the tail lights come on. other then that they don't work. I have wired in a new one and the problems still there what do i need to do.
Old Feb 2, 2013 | 02:12 PM
EddieE's Avatar
The stop lamp switch at the top of the brake lever is working, so you are saying there are no rear lights other than when the brake is pressed? Have you tried using the manual push/pull headlight switch and slowly moving it in and out while someone observes the lights? I am thinking what you are describing is possibly a headlight switch problem, a common issue with the GM's.
99couger
May 7, 2007 09:38 PM
MehlodyAura
Sep 22, 2006 03:36 PM
MehlodyAura
Sep 22, 2006 03:06 PM
MehlodyAura
Sep 22, 2006 03:02 PM
MehlodyAura
Sep 22, 2006 02:47 PM
