Closing in on a 4.6
Monte - Indiana - nice 2meet cha ,)
Bought this land yaught (gotta love 'em!) 3 years ago with 35K on her - paid WAY 2 many $ 4 it... Finished replacing the plastic, fantastic intake jokeafold today. Long time coming. Results as expected - almost. Still has a slight stagger just off idle. Starts funny - cranks a while unless you touch the gas. Everything says PCV valve - as in, wrong one. Parts stores sell me a "universal" thing that "fits" every small block ford v-8 made since they had pcv... CLOSE, BUT NO BANANA... I'm like, soooo close now. Anybody been here and figured this out? |
PCV Valves for Grand Marquis
Hello, Art, and welcome to the Mercury Forums --
PCV Valves for the Grand Marquis ain't all the same -- and you didn't give the YEAR of your ride, SO -- I searched 'em all -- 1980 - 2002 = Motorcraft - EV98-B 2003 - 2004 = Motorcraft - EV258 2005 - 2006 = Motorcraft - EV273 2007 - 2009 = Motorcraft - EV279 2010 - 2011 = Motorcraft - EV281 Motorcraft parts available at - RockAuto.com If yours is Electric, make sure that the power is getting to the Valve. Good Luck ! https://cimg9.ibsrv.net/gimg/www.mer...d8bb92bac3.jpg 95 MERC Engine Bay |
congrats on the find!
Originally Posted by 95 MERC
(Post 25275)
PCV Valves for the Grand Marquis ain't all the same -- and you didn't give the YEAR of your ride, SO -- I searched 'em all -- 1980 - 2002 = Motorcraft - EV98-B 2003 - 2004 = Motorcraft - EV258 2005 - 2006 = Motorcraft - EV273 2007 - 2009 = Motorcraft - EV279 2010 - 2011 = Motorcraft - EV281 Motorcraft parts available at - RockAuto.com If yours is Electric, make sure that the power is getting to the Valve. Good Luck ! https://cimg9.ibsrv.net/gimg/www.mer...d8bb92bac3.jpg 95 MERC Engine Bay No more stutter on takeoff. Still started funny. As I am ancient, I remembered something we used to call VAPOR LOCK. It's when a gas line gets so hot the fuel evaporates inside it. I removed the "hat" from the motor and bled the fuel rail. Just undo the cap for the pressure test and GENTLY push the tire style adapter. It hissed, first time, and no fuel came out. BINGO! DO NOT do that with the motor running! That's an engine fire, right there! Start it, shut it off, bleed then repeat, until no more air comes out - just fuel. I had to do it only once. So now it's like, 99%. Still stumbles when idling in gear. Might be it doesn't like the plugs I put in it - Bosch, thin-wire, double iridium. The IAC and the EGR are brand new - bought them before I learned about the manifold thing... And, so it goes - rofl! |
| All times are GMT -5. The time now is 01:59 AM. |
