-   -   Difficulty Starting Grand Marquis (https://www.mercuryforum.com/forum/grand-marquis-14/difficulty-starting-grand-marquis-857/)
lugnut Dec 6, 2006 01:46 AM
In the past couple of weeks,I have noticed my 1996 Grand Marquis will occasionally die when I first start it. I can restart it & it runs fine. Any ideas as to what might be the cause of this?
smartyss17 Dec 31, 2006 12:47 PM
if that happenswhen it is cold, thenmy car has exactly the same prob......i have no idea why.
bilwil Aug 14, 2007 11:02 AM
i have a 2000 thats just started doing the same thing,i hope you find the problem,when you try to start mine it acts like its not getting enough gas to keep it going,and trys to run real slow and dies,after 3 or more tries it will go slow at first then faster till ok,,then its fine for the day??
92Mercury Aug 14, 2007 12:46 PM
Onepossible cause:
There is a little sensor (bright orange) in the air intake, in the hose that runs of the air filter cover to the intake. It is part of the control for the air/fuel mixture.
When shops "jerk" the cover around in order to check the air filter, the sensor very often gets broken. It is a little round sensor, looks like a penny, bright orange, and is mounted only with 2 little legs which easily brake.
I had a similar issue and found one of these legs broken. I soldered it back on, and my identical problems when the car was cold were gone.
Also, and I haven't figured this one out yet,the car is either hard to start or dies right away, which seems to be persistent in especially these hot days. It happens on my '92, and my buddies '00. Now, if we turn off the air (compressor), the issue is gone.
The air compressor is activated via a electric clutch, which seems to engage for a moment as soon as the ignition is turned on. So it puts some force on the engine when started and seems to make it harder for it to start right away.
Sounds strange, uncommon, but with the a/c off, it's gone. Might want to give it a try and see.
Besides all these little gizmo's, even on a '00 model, after 7 years of service change of the fuel filter and a tune up might sometimes do miracles.
Greetings!Edited by: 92Mercury
Matt73 Feb 2, 2008 08:27 PM
My car did that and all i did was change the plugs.. problem solved!< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45";
urchinTracker();
cinquea Feb 25, 2008 05:19 PM
I
cinquea Feb 25, 2008 05:22 PM
I had the same exact problem during starting. The dealer replaced the Idle air control valve and the problem was resolved.My car is a 2000 MGM. Tony.
86VickyLX Feb 27, 2008 09:17 PM
if that happens when it is cold, then my car has exactly the same prob......i have no idea why.
That's the IAC Sensor on the intake, sounds like it's got some gunk in it or something, that's not allowing it to function properly when it's cold out. Once it's running for a bit, it'll stay running.
86VickyLX Feb 27, 2008 09:24 PM
Originally Posted by 92Mercury
One possible cause:
Also, and I haven't figured this one out yet, the car is either hard to start or dies right away, which seems to be persistent in especially these hot days. It happens on my '92, and my buddies '00. Now, if we turn off the air (compressor), the issue is gone.
Greetings!
You shouldn't start a car with the A/C on anyway, it takes alot of force to get that clutch to spin.
conan312 Mar 2, 2008 10:23 AM
Hey lugnut, you just need to clean the IAC motor. That should do it. If you are feeling generous and she is in need, give her a full blown tune-up and make her happy! Don't forget the fuel filter!!! Let me know, it has been a couple months since you posted the prob.
