-   -   DIY abs repair (https://www.mercuryforum.com/forum/grand-marquis-14/diy-abs-repair-1819/)
blake67 Jun 11, 2008 08:54 AM
ok I figured out how to get the trouble codes, two of the codes are wheel sensor which probably just need cleaning no biggie. the other two codes are LH rear outlet valve and pump motor pressure, not sure about rear outlet valve, does anyone know what that is? and could someone explain about the pump etc?
94 MGM
4.6l engine etc
