-   -   electrical problem (https://www.mercuryforum.com/forum/grand-marquis-14/electrical-problem-1042/)
lkmfcars May 15, 2007 03:37 PM
Have a 95 gm,what would cause the head lights,turn signals,door locks,radio,clock,brake lights except for light in the back window,to all of a sudden go nuts,and then not work.the car runs good,wipers work,power windows work.checked all fuses that I could find,under dash,under hood all ok.Oh yeah interior lights dont work either,but they did go on and off by themselfs.my wife thinks there`s a ghost because she was driving when it happened.
92Mercury May 24, 2007 09:20 AM
Hi there!
Interesting to see, many people out there with similar issues like I had.
OKay, first of all, the car is 12 years old, and the parts on it, aging the most, are usually seals (rubber), plastic (hardens) and electric wiring.
Second, "go nuts" is not a term to which you will get helpfull input. You have to be specific.
On mine, the ground wire on the transmission/firewall did not have good contact. Re-attached, most issues are gone.
The door lights might need the switches (next to the door hinges) to be taken out and cleaned. Again, corrosion, cause they are grounded.
Regards
