I just purchased a 94 Grand Marquis... the headlights are cracked and moisture is inside and the tailights are cracked... What lights are interchangable?Will the lincoln lights or the ford Crown vic lights fit the grand marquis? |
Well, then again: '94 model or year built? Cause headlights and taillights changed from '94 to '95 model, and are not interchangeable, unless you do major modifying. Let us know, and then we go from there. Greetings! |
Thanks... I just read the other post... :) Would I check the door panel to find out if it was a 94 model or 94 built? |
Do so, I posted the pics there.
