High Performance Brake Fluid
For those of you that demand optimum performance from your vehicle's braking system, there is a new Brake Fluid type that should interest you.
Made by Bosch, the new fluid designation is ESI6-32N -- replaces and is compatible with: DOT 3; DOT 4; and DOT 5.1. The new fluid has a lower viscosity, which allows for better functioning of anti-lock brake systems, plus the added bonus of longer service life. Fluid life is double that of the standard DOT 3 fluid. Dry Boiling Point = 270 C. - 518 F. Wet Boiling Point = 185 C. - 365 F. Comes in a 32-OZ metal CAN -- available at O'Reilly's and Amazon.com. https://cimg1.ibsrv.net/gimg/www.mer...4ffba9458b.jpg Eclipse Calipers; Motorcraft Police Pads; ACDelco Drilled&Slotted Rotors; ESI6-32N Brake Fluid; Centric Hoses. |
