Related problem, safety belt alarm on at any time driver door is open, even with no keys in ignition or any lights on. This problem developed after changing the turn signal switch at the mechanic. Not going back to the dumbass (who knows what else he finds wrong, this was his second and final mistake), any suggestions ? Did he steal my airbag ?
1990/91 Mercury Grand Marquis LS. |
sounds like he may not have connected everything back up correctly in the steering column when he put it back together. That, or a relay has stuck on. stolen airbag wouldn''t do anything like that. at worst, nothing would be noticeable with a stolen airbag. at best, the airbag light would be on all the time. There may also be something laying loose inside the steering column that may be shorting something. might just take the shroud off (top and bottom covers) and see if there''s something obvious.
Ok, thanks, I think I can do that.[img]smileys/smiley16.gif[/img]
Originally Posted by Mer.Gra.Mar
(Post 7682)
Tripper511 :
<DIV id=result_box dir=rtl style="TEXT-ALIGN: left" align=left>If the seat belt alarm canceled from yourcar , this would be automatically cancel the air bag</DIV> |
How to get the seat belt chime/ warning bell to stop going off.
First go under your seat. Second look at the bottom of you seat belt lock for some wiring coming out of it. Three follow the wire until you find where it is plugged in at. and four unplug the wire. this should stop the chime from going off.
