Humming noise when i only turn right.
Old May 28, 2008 | 11:08 AM
jason sereiko's Avatar
Has anyone had this problem before? I get a humming noise only when i turn right. It sounds like it is comming from the pass side front tire. Is this a bearing or something else. It does not seem like it is the tire rubbing. It looks like there is enough clearance for the tire. They are ther stock tires. Just want to know if my tire is going to fall off or if this is an easy fix. Thanks for looking at this question. Jason
Old May 28, 2008 | 07:55 PM
BFM70's Avatar
Jack that side up. Grab the tire top and bottom and see if there is any play. You should not get any play from the wheel this way. If there is play, that wheel bearing is bad. Normally it's not a big deal to repack them, but the modern MGM's have lifetime sealed wheel bearings, and I haven't tried to open them up to see if they can be repacked.
searchlight4759
Jun 18, 2017 04:42 PM
Larry Vance
Apr 23, 2013 08:17 AM
walnut777
Mar 2, 2010 10:31 AM
mtbower07
Sep 22, 2009 12:20 PM
chrisbradbury
Sep 1, 2006 01:32 AM
