Idling/Running Problem
Old Sep 9, 2009 | 03:46 PM
MJB DIGITAL's Avatar
Default Idling/Running Problem
88 GM
On the road, when I give her gas she wants to stall for a bit, then she gets the juice flowing and goes.
also,
When I'm in park and idling, she wants to stall and goes into a rythm where the idle goes way down and back up and back down again. Occasionally she does die. When I put her in reverse, she might die or she might not.
Thanks for input.
I'm going to start with plugs, wires, cap and rotor. I also need a valve cover gasket.
Any input?
Old Sep 10, 2009 | 01:38 AM
maxfax3's Avatar
Tuneup is a very good place to start!!! YOu may want to change the fuel filter while you are at it...
THe other thing to try as far as the idling is to clean the throttle body and idle air control valve.. Simply remove the big rubber hose from the throttle body (gonna have ot off to do plugs anyhow) and spray the heck out of it with carb cleaner.. THe idle air motor bolts on to the throttle body.. Remove the 2 bolts and plug that hold it on and clean it out much the same way as the throttle body.. You may need a new gasket for it upon reinstallation....
Good luck!
Old Sep 10, 2009 | 03:31 PM
Thanks!
OK....
Plugs, wires, cap, rotor, valve cover gasket, clean throttle body, and idle air control, and a new gasket for that.
woot!
I love working on my car. 8)
Old Sep 10, 2009 | 04:37 PM
maxfax3's Avatar
Since you'll have it disconneted anyways upgrade to the brass bushing for the throttle valve cable (the one to the trans) if it hasn;t been done already.. Your transmission will thank you!
Old Sep 10, 2009 | 05:45 PM
visual aids here: http://www.lincolnsonline.com/tech/00052.html
Old Sep 11, 2009 | 08:21 AM
four bucks??! will do
but i'm putting off any more maintenance till i can get this situation solved:
https://www.mercuryforum.com/forum/s...ead.php?t=3266
kinda pisses me off
Old Sep 11, 2009 | 10:11 AM
maxfax3's Avatar
Wow what a cluster.. At least the guy is willing to work it out..
Old Sep 13, 2009 | 08:27 PM
yeah but he hasn't responded to the last email i sent him breaking it down to say how much the fees are going to be and why. i think im going to end up paying for it....with a couple of donations from friends.
Old Sep 13, 2009 | 11:53 PM
  #9
since you have all that stuff being replaced... get a new rubber that holds PCV ... install new PCV and under that is a PCV screen thaty rarely ever gets changed that contributes to making oil leaks.
Old Sep 14, 2009 | 01:38 PM
  #10
maxfax3's Avatar
AS much as it sucks, that's usually how it goes.. Be glad you can at least get it transferred...
