-   -   Idling/Running Problem (https://www.mercuryforum.com/forum/grand-marquis-14/idling-running-problem-3267/)
MJB DIGITAL Sep 9, 2009 03:46 PM
88 GM
On the road, when I give her gas she wants to stall for a bit, then she gets the juice flowing and goes.
also,
When I'm in park and idling, she wants to stall and goes into a rythm where the idle goes way down and back up and back down again. Occasionally she does die. When I put her in reverse, she might die or she might not.
Thanks for input.
I'm going to start with plugs, wires, cap and rotor. I also need a valve cover gasket.
Any input?
maxfax3 Sep 10, 2009 01:38 AM
Tuneup is a very good place to start!!! YOu may want to change the fuel filter while you are at it...
THe other thing to try as far as the idling is to clean the throttle body and idle air control valve.. Simply remove the big rubber hose from the throttle body (gonna have ot off to do plugs anyhow) and spray the heck out of it with carb cleaner.. THe idle air motor bolts on to the throttle body.. Remove the 2 bolts and plug that hold it on and clean it out much the same way as the throttle body.. You may need a new gasket for it upon reinstallation....
Good luck!
MJB DIGITAL Sep 10, 2009 03:31 PM
Thanks!
OK....
Plugs, wires, cap, rotor, valve cover gasket, clean throttle body, and idle air control, and a new gasket for that.
woot!
I love working on my car. 8)
maxfax3 Sep 10, 2009 04:37 PM
Since you'll have it disconneted anyways upgrade to the brass bushing for the throttle valve cable (the one to the trans) if it hasn;t been done already.. Your transmission will thank you!
slymer Sep 10, 2009 05:45 PM
visual aids here: http://www.lincolnsonline.com/tech/00052.html
MJB DIGITAL Sep 11, 2009 08:21 AM
four bucks??! will do
but i'm putting off any more maintenance till i can get this situation solved:
https://www.mercuryforum.com/forum/s...ead.php?t=3266
kinda pisses me off
maxfax3 Sep 11, 2009 10:11 AM
Wow what a cluster.. At least the guy is willing to work it out..
MJB DIGITAL Sep 13, 2009 08:27 PM
yeah but he hasn't responded to the last email i sent him breaking it down to say how much the fees are going to be and why. i think im going to end up paying for it....with a couple of donations from friends.
87_Crown_Vic Sep 13, 2009 11:53 PM
since you have all that stuff being replaced... get a new rubber that holds PCV ... install new PCV and under that is a PCV screen thaty rarely ever gets changed that contributes to making oil leaks.
maxfax3 Sep 14, 2009 01:38 PM
AS much as it sucks, that's usually how it goes.. Be glad you can at least get it transferred...
