| slymer |
Nov 8, 2008 05:50 PM |
yeah... probably the coil... do check the plugs and wires while you''re at it. also if it''s a distributor system, check the cap and rotor for wear. it could also be the ingnition module. If it''s a distributorless system, it could be the coil packs (should be one mounted on each valve cover) or the ECM. I would think that if it''s the latter 2, it would be giving codes. You may want to see of you can get the computer read and see if there''s any codes that may help diagnose this.
