-   -   installing a rebuilt trans o7 can i program it with forscan (https://www.mercuryforum.com/forum/grand-marquis-14/installing-rebuilt-trans-o7-can-i-program-forscan-12093/)
jbl420 Jun 22, 2021 01:40 AM
I was told i had to reprogram by some guy after the install . the company i wanted to by from said i did not have to go to the dealer to program anything what a guy from the company told me i just need to reset the adaptive tables does that make sense? i have the scan tool and the software
Josephmorrison Jun 22, 2021 04:40 AM
I worked in a transmission shop I never had to reprogram one yet it should learn the shifts on its own.
Josephmorrison Jun 23, 2021 04:23 AM
We just took them out and drove them. We had the batteries disconnected to so maybe that did a reset. Depending on the years to you might have to but I haven't had to do anything yet.
95 MERC Jun 23, 2021 04:40 AM
Reprogram Transmission With Forscan
You should have no problems with re-programming your 2007's Transmission with the Forscan software -- if by "re-programming" you mean to tune your shift points for better strip times or fuel mileage.
You will need a tool to attach a Laptop to the OBD2 Port:
If you just wanna use the factory shift points, nothing needs adjusting. It's plug & play !!
https://cimg2.ibsrv.net/gimg/www.mer...177a15f4d5.jpg
95 MERC at Flaming Gorge, Utah. US 191 at South end of the Gorge.
