-   -   joint lube (https://www.mercuryforum.com/forum/grand-marquis-14/joint-lube-5526/)
jrmartinez59 Apr 8, 2011 03:30 PM
joint lube
I have a 2000 Grand Marquis that I purchased a year ago and I wanted to lube the joints. However, there seem to be no grease fittings anywhere. What can I do??
Juan
mcmerc Apr 10, 2011 11:26 AM
I have a 2001 Grand Marquis with 15,000 original miles. None of the front end parts have grease fittings. I recently had a shop change the idler arm because it was not stiffer than the other components. I have heard that there is a way to inject some lubricant with a syringe through the rubber boot. My car does not handle well under certain conditions. I think that some of my fittings are too stiff.
jrmartinez59 Apr 12, 2011 07:22 PM
joint lube
I can't believe they would build something like that!
Thanks for the feed back.
Juan
87_Crown_Vic Apr 12, 2011 07:52 PM
many replacement parts have the grease fittings... syringe with grease is a way to do it thru the boot... and the way your car handles isnt due to tight parts, but more than likely worn out shocks and sway bar bushings being worn...
