lighting control module
Have a 95 grand marq,need to know where the lighting control module is.Is there a way to bypass it.car doesnt have any head lights,tail/break lights/signals/door locks/radio/dome lights.it runs good.power seats work,power windows work,ac/heater works,cyclops break light in the back window works.wife thinks its haunted because all the things i mentioned was going on and off while she was driving.thanks tony
you have a bad ground or the wire that connectes to the back of the fuse panle is loose. The fuse might be good but you have to check the wire behind it for those lights. you need a volt meter and to see if you have a steady current. let me know if you have a current for the main wire in the fuse panel
R they still going on and off or did it do this before and now they totally stopped. You have some fuses under the hood and in the main fuse panel. I need some more info. is this a new car you purchased. if so they could of put in a wrong fuse and it burned out that panel. make sure you have a 25 fuse in the 25 foe example, not a 15 fuse in a 25 because it will burn the fuse so hot that it can cause the panel to burn the wire.
