lost woodruff key from windshield
Help! I know this is a small minute problem, but it is a problem. While pulling the windshield wiper arms off to find a water leak the woodruff key out of one of my wiper arms fell off and slipped into the space-time - continueum under the hood to never be found again. Where can I get another woodruff key for this car?
Thanks, Chuck |
might try a hardware store. Get a washer with the same thickness and curve and grind it down to the same size.
slymer,
Thank you much. I was hoping one of you guy's was going to say "just call this number and send them $2.00 and your problems are solved". Actually I knew better but I can dream. I went to Ace Hdwr. and bought a long woodruff key, took my bench grinder and dremal tool and 45 minutes later I put the car back together. Thanks again, Chuck |
that's my solution for most things like that... find something close and grind it to work. That's how I fixed the odometer on my wife's 93 vic. found a 26 tooth RC gear and ground it down to size. replaced the broken planetary gear in the odometer and all's better.
| All times are GMT -5. The time now is 06:44 AM. |
