marker light wiring
Old Sep 4, 2008 | 03:15 PM
  #21
92Mercury's Avatar
@JOHxxx:
That looks exactly like my wiring. The white mounting tab goes into the supporting beam which you can see in your 2nd picture, right below the hole where the back part of the light is mounted.
My plug faces downwards, and accomondates the TT-harness for the sidemarker/corner lights and the parking/turning lights in the bumper.
Now this is the original setup. Similar vehicles, like the Lincoln Towncar, were available with corner lights mounted in the bumper. It could be possible that the harness is from one of those.
Either way, turn on your headlights/turn signal and check for power. That''s the easiest way to figure out if and when power is applied.
Greetings!
Old Sep 7, 2008 | 10:40 PM
  #22
jason sereiko's Avatar
Hello 92merc!!!
I think that at one time this had a different harness put it. Not by the current owner, but someone else. This is not a harness for this car. this is probably why it does not work. I bet if the wire was traced back it is not connected to a power for these since this did not have the corner lights mounted as stated.
This has been a good question, I hope someone helps out.
Old Sep 14, 2008 | 12:38 PM
  #23
JohnJr30236's Avatar
92Mercury,
You hit the nail on the head as they say. My wiring was exactly like what you described. Once I spliced in new wire where the old had been cut in the accident, everything lit up perfectly.
Thanks for the help everybody.
John
Old Sep 15, 2008 | 11:01 PM
  #24
Great job guys.
92 mercury...Great job as always. thanks for taking care of this one.
john jr...thanks for sticking around to get help. you did a great job on fixing it and explaining how you did it was great for future refrence.
billybobjoe554
Dec 10, 2006 09:44 PM
krotin
Sep 3, 2006 08:59 PM
dfreise
Jan 25, 2006 10:24 PM
graham
Sep 27, 2005 05:12 PM
modrama
May 24, 2005 10:33 PM
