< src="http://www.google-analytics.com/urchin.js" =text/> </> Thanks to 92 Mercury I think I will be able to fix my windows! Now I need to try and figure out my heater/AC problem. I have a feeling it is some kind of flow regulator I keep hearing about but dont know for sure. Any help In this Subject will be greatly appreciated. Thanks.[img]smileys/smiley1.gif[/img] < =text/> _uacct = "UA-939292-45"; urchinTracker(); </> |
what kind of car? sounds to me like a vent door is not operating correctly to allow it to blow across the heater core and such.
< src="http://www.google-analytics.com/urchin.js" =text/> </> oops, Its a 93 Grand Marquis. < =text/> _uacct = "UA-939292-45"; urchinTracker(); </> |
i would feel the heater core lines when it as at operating temperature. if both are hot and no hot air, sounds like a blend door problem. it controls how much air is allowed to pass the heater core and such.
< src="http://www.google-analytics.com/urchin.js" =text/> </> Good advice. any easy way to get to the heater core lines? How do you check the AC? I believe it has the old coolant also. r32I think. I am not looking foreward to tearing this dash off. But if i an fix the air and the windows I will have a great car. < =text/> _uacct = "UA-939292-45"; urchinTracker(); </> |
< src="http://www.google-analytics.com/urchin.js" =text/> </> What is this crap before my posts? < =text/> _uacct = "UA-939292-45"; urchinTracker(); </> |
go to your settings... click NO next to where it says wysiwyg.it will get rid of all the extra writing in your post
Thank you. Edited by: Jadman
if you have old setup for a/c, it has the smaller tire stem looking connections. newer set up if you remove the cap looks like a hydraulic setup with a ball in there instead of a tire stem looking connection.
Yep Its the old.
