Oil in #1 spark plug hole
Old Jul 4, 2010 | 10:28 AM
lxtynan's Avatar
Default Oil in #1 spark plug hole
Oil is accumulating in #1 spark plug hole and causing an engine miss. Does not appear to be comming from the valve cover and intake manifold does not look like it has any oil passages. "97" 4.6cid Grand Marquis. Anyone had this motor appart got any ideas?
Old Jul 15, 2010 | 09:50 PM
littlejohn2458's Avatar
sounds like a valve could be sticking or maybe the valve guide might be getting oil past it. I work on Yamaha Marine engines and they have the same heads and stuff that for uses. When we foul the 4 stroke plugs with oil its because of the valves or the guides leaking.
Old Jul 16, 2010 | 09:23 AM
lxtynan's Avatar
The oil is outside the combustion chamber in the cavity the spark plug goes in and around the outside of the spark plug.
Old Jul 16, 2010 | 07:59 PM
oh ok i see. Did you get your oil changed lately? maybe the lube guy dumped some oil down there or something? if its on the outside of the spark plug i dont see why it would create a misfire. Just change the plug and get some new wires. Start you vehicle at night in the dark and look for sparks or a broken wire. do a pressure check and make sure that your fuel pump is not going out or that your fuel pressure regulator is also not going out. I have seen it where an EGR has also gone bad and has caused an engine miss.
Terry
Feb 17, 2019 11:26 AM
Sparkplugs.com
Sep 1, 2017 03:22 PM
Smokefan
Apr 24, 2009 07:55 PM
andrew65
Jan 24, 2009 05:53 PM
gordoj52
May 9, 2007 03:43 PM
