Pwr Steer Hoses - Ramps or Jacks
95GMLS -Replacing power steering hoses. Is it easier with car rolled up onto ramps (suspension normal) or lifted onto jacks (suspension loose/sagging)?
Thanks. Mike |
I think you would do better with the car on ramps (suspension normal).
Actually, the easiest way to replace the power steering pump and/or hoses is to remove the driver's side fender liner -- to give easy access to the pump and the hoses. Take your time -- and DON'T do any "short-cuts". Good luck !! |
