-   -   REMOTE CONTROL (https://www.mercuryforum.com/forum/grand-marquis-14/remote-cntrol-1310/)
coupe Oct 17, 2007 07:32 AM
i get a new transmitter for the remote control. how can i programmed it?
coupe Oct 18, 2007 09:08 AM
i find it out, only with the Keypad on the door. But, it doesn´t work, i habe this trouble-code:
B1525 Keyless Entry Circuit Short To Battery
what meen´s that and what can i do about it?
</pre>
92Mercury Oct 19, 2007 08:45 AM
Probier's mal mit vernünftiger Vorstellung in der Rubrik "Neue Mitglieder".
Und ohne Angabe von Baujahr, Typ und Modell kannst Du lange auf Hilfe warten. Wir sind keine Hellseher.
Greetings!
coupe Oct 22, 2007 01:36 PM
Mercury Grand Marquis 1996 4.6
92Mercury Oct 22, 2007 03:49 PM
Much better. Cause they changed programming features late in 1995. Sometimes it's the same, sometimes it's different. Ford, oh well.
Am not sure about this model year, but before that, keypad on the door did notmeanthat you have a remote transmitter. As a matter of fact, on the '92 models only the keypad was available, no remote transmitter at all.
Anyhow, you error code indicates a short ('nen kurzen, Kurzschluss). Easiest fix is taking the keypad off and clean the contacts. Eventually, throughout all the years, water and particles found their way inside and can cause all kinds of issues.
If that doesn't fit it, the search will start. But first we would need if and what it is doing.
Greetings!Edited by: 92Mercury
coupe Oct 23, 2007 02:17 AM
okay, thx! i will try that
92Mercury Oct 23, 2007 09:56 AM
Here's the manufacturers article on how to do program the system:
A03-18-1RemoteKeylessEntry.zip
It's a PDF file, but the forum does not allow upload of that kind of file.
Greetings!
coupe Oct 23, 2007 11:39 AM
wow, thank you
92Mercury Oct 23, 2007 12:39 PM
Use the search function. There is a post under General Tech Help, which shows the programming for all kinds of Ford/Lincoln/Mercury vehicles.
Greetings!
