-   -   Replacement of spark plugs (https://www.mercuryforum.com/forum/grand-marquis-14/replacement-spark-plugs-6759/)
rocasan Apr 24, 2013 08:30 AM
1998 Mercury Grand Marquis
I want to know the cost of replacing spark plugs (material and labor) as I believe I was overcharged at a local shop.
Please advise.
wohara Apr 25, 2013 04:03 PM
I was quoted $600 for a diagnostic and tune up which involved replacing the sparkplugs. I thought they were crazy so I did it myself. After finishing, I realized why they charge so much. It isn't very difficult but you have to remove the fuel rails and I damaged two of the injector O rings in the process. You might even consider having replacements on hand if you are going to do it yourself.
Limoguy May 19, 2013 06:36 PM
You can find a shop to install new plugs for under $150 if you shop around
rocasan May 20, 2013 03:50 PM
Thank you so much for your information.
brand2029 May 27, 2013 03:17 PM
I did my cap Rotor and plugs And wires, and (parts) were $78, and OEM parts ....
I did all work my self. in 1 hour, taken my time.
Bimmer Oct 22, 2015 10:22 AM
I just did mine and it was easy. The boots are so flexible that you do not have to remove the fuel rails at all.
MississippiMark Dec 7, 2015 08:44 AM
Copper, iridium, or platinum? Has anyone noticed a difference in mileage or performance with replacement spark plugs or is it simply a matter of how often you have to replace them?
sdu754 Jan 16, 2016 09:55 PM
On that model year Ford used a 2-part spark plug that tended to break off in the engine, many dealers don't want to touch them. That's why the price is high, they are a pain.
Andrewski Jan 14, 2017 10:43 AM
Plugs? Just changed a set of factory installed Iridium's on a Kia Sorento that had 100K miles on them, and they looked like new. I plan on using them on my next '03 Marquis change out.
95 MERC Mar 19, 2017 01:53 PM
Spark Plugs '92 -'10 Grand Marquis
The best type and part number for the 1992 - 2010 Grand Marquis is the BOSCH #9606, which is a Double-Iridium type that is superior to the OEM platinum type that's fitted at the factory, and it has exclusive features that other plugs just don't have.
Currently available at ROCKAUTO.COM for $5.02 each.
I have used these plugs in my '95 Grand Marquis restoration project car, with excellent performance and fuel economy, regardless of altitude and/or outside air temperature.
Silky-smooth idle, excellent throttle response, and excellent fuel mileage on 87-octane gas (with 10% ethanol).
If you have the twin coil packs, replace the ignition wires with Bosch Premium Mag-Core ignition wires.
I got my wires from Amazon.com.
When changing plugs and wires, it's a good time to remove and inspect the coil packs for carbon tracking or other problems.
Test the coil resistance with an Ohm meter.
Should be 0 to 1 Ohms for the primary - (lower is better).
14.5 Ohms is ideal for the secondary.
If coils test good, spray them with WD-40, then wash them thoroughly with soap and water.
Spray the terminals with WD-40 before re-installing the coils.
When done right, your ignition system should be trouble-free for 75,00 - 100,000 miles.
