-   -   Strange noise/vibration (https://www.mercuryforum.com/forum/grand-marquis-14/strange-noise-vibration-4027/)
merky_marquis Feb 9, 2010 03:01 PM
Originally Posted by yockit (Post 12792)
Hi, it's the air pump, comes on to lift the rear and you my hear it release air when the car is on or off.
That's kind of what I'm thinking too.
OP if you can take a video that would help us quite a bit.
Also check and see if you have air bags or coil springs on the rear of the car, if someone has already done a coil conversion then their is no need to have the pump anymore
JerseyTrueBlue Feb 24, 2010 06:02 AM
That was one of the noises, I stated above^
DefEddie Feb 24, 2010 10:16 AM
The clicking noise is one of the blend door motors more likely.
It comes on at key on and at key off?
Sound like the blend door,it will default in both conditions.
Normally the door will just open/close,you hear a clicking because the plastic gear inside the actuator is stripped more than likely.
Common issue.
