Thermostat Question
Old Mar 13, 2010 | 03:49 PM
89GrandMarquis's Avatar
Default Thermostat Question
Hey there every body i finally got my self a master-craft tool set no i now fixed my alternator and my door handle finally opens from the out side so I am really on a roll haha. So now I am ready for the next level to change the thermostat but I'm not sure where it is located can any one help me out i no how to change it and replace the gasket but i don't know where it is thanks.
Old Mar 13, 2010 | 07:07 PM
follow the top radiator hose back to the engine... it's in that dome shaped housing. Should be 2 bolts and lift. Clean surfaces of any gasket material/sealant and remove thermostat. Install new thermostat and gasket/sealant and bolt back in place torqued to spec (12-15 ft.lbs). Make sure to note the orientation of the old thermostat so you get the new one installed in the proper direction.
rdondes
Nov 27, 2019 01:06 PM
rfellmanjr
Apr 30, 2010 07:00 AM
rfellmanjr
Apr 12, 2010 07:24 PM
Ajwheeler66
Jan 25, 2008 11:47 PM
waggy
May 1, 2006 05:05 PM
