-   -   Thermostat Question (https://www.mercuryforum.com/forum/grand-marquis-14/thermostat-question-4142/)
89GrandMarquis Mar 13, 2010 03:49 PM
Thermostat Question
Hey there every body i finally got my self a master-craft tool set no i now fixed my alternator and my door handle finally opens from the out side so I am really on a roll haha. So now I am ready for the next level to change the thermostat but I'm not sure where it is located can any one help me out i no how to change it and replace the gasket but i don't know where it is thanks.
slymer Mar 13, 2010 07:07 PM
follow the top radiator hose back to the engine... it's in that dome shaped housing. Should be 2 bolts and lift. Clean surfaces of any gasket material/sealant and remove thermostat. Install new thermostat and gasket/sealant and bolt back in place torqued to spec (12-15 ft.lbs). Make sure to note the orientation of the old thermostat so you get the new one installed in the proper direction.
