turn signal flasher
can anyone tell me where the actual flasher is on my 2003 grand marquis? I have searched, and all i find is where the turn signal fuse is. I need to change the flasher relay itself to a heavy duty one. Thanks for your help.
Turn Signal Flasher
If you live near an AUTOZONE store, take it there. Buy the flasher from them, and have them install it.
It's almost always FREE. I've had the 95 MERC for 15 years, and I STILL don't know where the flasher is located. Good Luck !! https://cimg9.ibsrv.net/gimg/www.mer...d8bb92bac3.jpg '95 MERC Engine Bay |
Originally Posted by badboy368
(Post 23644)
I just switched over to LED bulbs in the turn signal / marker lamps, and I am getting a fast flash. Should I switch back? or is there another solution?
LED Resistors
Due to the low voltage of the LEDs, a resistor is added to the circuit in order to bring the flash to the proper duration.
Resistor Kits ( includes instructions) are available from Amazon.com . -- not expensive. E-Z install -- no special tools or skills required. Picture shows LEDs installed in Parking Lights -- and one Headlight. https://cimg7.ibsrv.net/gimg/www.mer...fc6a0156a6.jpg LED Headlight Bulb, Passenger Side -- Halogen Bulb, Driver's Side. Resistor Kit installed in Parking Lights. 4Pcs Aaron 50W 6ohm Load Resistors - Fix LED Bulb Fast Hyper Flash Turn Signal About 5 years in use -- NO problems of any kind. And I can SEE !! |
perfect Thank-You very much
| All times are GMT -5. The time now is 06:26 AM. |
