Voltage regulator
Old Mar 28, 2019 | 09:54 AM
Kevin Demery's Avatar
Default Voltage regulator
What is the location of the voltage regulator on a 95 grand Marquis? It’s not in the alternator and I don’t see it on firewall. Someone suggested that it may be on a radiator mount near the battery. I did locate a black box on the drivers side fender well. Thanks
Old Mar 28, 2019 | 11:05 AM
Default '95 Grand Marquis Voltage Regulator
The '95 Merc Grand Marquis parts listing at RockAuto shows 2 different Voltage Regulators.
My '95 MERC (built MAY, '95) has the VoltReg on the BACK side of the Motorcraft alternator, near the bottom. It has a 3-wire, plug-in connector. Be CERTAIN that the VoltReg is NOT mounted on the alternator before looking further.
The alternative Motorcraft part is not mounted on the alternator, and it has a flat-blade-type connector.
Here's a pic of the flat-blade type: The pics should help you find your regulator.
The lower pic is the Voltage Regulator that mounts on the back side of the Alternator.
Jesus Garcia
Apr 9, 2018 10:36 AM
lugnut
Oct 24, 2017 11:20 AM
2006montegoman
Nov 18, 2014 09:13 AM
aholmquist
Mar 24, 2014 11:22 PM
sminnis
Aug 3, 2011 10:46 PM
