volts volts volts
ok hopefully you guys have been reading my other thread on my volt problems. i got it back from dealer today and this is what they said.
ran charging system and battery load test: passed
ran key off load teast on battery .07 amps
spec is no more than .05 amps
cause is aftermarket cd player
also light control module not working properly lights sometimes dont turn off with switch.
need to run a diag on light control module $125 if bad might solve problem to replace if bad $549
i have never noticed that the light switch only worked sometimes B.S and when i got home i removed cd player and no change so i confused what to do any ideas
