Unfortunatly as it stands right now my poor 1992 Grand Marquis IS DEAD.
I was driving to work at about 60mph and the driver side tie rod broke and i took her into the ditch.... sustained damage so far that i have seen that WILL be fixed is as follows: Hood Drivers side fender entire driver side suspension windsheild driver side headlight assembly front bumper oil pan and driveshaft [img]smileys/smiley19.gif[/img] [img]smileys/smiley19.gif[/img] [img]smileys/smiley19.gif[/img] [img]smileys/smiley19.gif[/img] [img]smileys/smiley19.gif[/img] [img]smileys/smiley19.gif[/img] i am very upset. but tomorrow i am going to look at a 92' mgm with no motor or trans same color wish me luck |
it isnt luck, it is skills that will let your Grand Marquis to rise from the dead and give you joy once again. sucks that something like that would happen going down the road. if it makes it any better, you are ok i hope and the car can b repaired. your car protected you while hurting itself.
bought the parts car swap started
excellent. new name for your car i thought of.... the Grand Marquis Frankenstein.many donor parts from another body being used to bring it back to life. i have a situation on my hands now where i have to come up with money. think i am gonna have to sell soe parts i have for my engine build so that i can have some money on hand. i will have to decide in next few days.
< src="http://www.google-analytics.com/urchin.js" =text/> </> Bad news. I agree with 87 Crown Vic - that Frankenstein will return meaner and better than before! Good luck with the project. < =text/> _uacct = "UA-939292-45"; urchinTracker(); </> |
83,94 Marquis99....
to get rid of the google crap, go to your settings and click no where it asks about the wysiwyg |
Sorry to hear about that. Why did the tie rod broke? I would inspect that first, you never know, it could happen on the other side as well.
Regarding the damage, that is not that bad, IMO. Hood an fender are easy to get (as they are identical through most of the face-lifts), a headlight new runs around $50, and all the other parts are not that expensive either. I guess it all depends on how "addicted" you are to this car. You can buy another one for the same amount of money you would have to spend on parts. But if you like to swap parts, well, then you got your project now. What's the story with the new one? Why no motor nor transmission? And I would certainly check out the tie rods! Good luck. Greetings! |
i would consider tie rod ends, pitman and idler arms getting replaced. how do the link pins look or are you gonna change those also?
| All times are GMT -5. The time now is 05:15 AM. |
