-   -   yellowed headlight lense (https://www.mercuryforum.com/forum/grand-marquis-14/yellowed-headlight-lense-1235/)
lugnut Sep 3, 2007 09:10 PM
[img]smileys/smiley11.gif[/img] My 96 grand marquis's plastic headlight lenses have yellowed to the point that itis not safe to drive it at nite.
Can these be cleared up with something or do I have to replace them ? I can hardly afford to do that.
92Mercury Sep 3, 2007 10:59 PM
Use the <Search> function.
https://www.mercuryforum.com/forum_p...6&KW=92mer cury
20marquis07 Nov 9, 2007 09:36 PM
[img]smileys/smiley2.gif[/img]
EZDUSIT Dec 27, 2007 08:56 PM
A lot of your problem is very fine scratches hacing glazed the surface of the lens. I found a product on e-bay for about $8.00, called Novus 2 that you apply as if you were waxing the car, let dry, then polish with a clean cloth. I use it on my old cars and it make a lot of difference, but you need to re-applt it every so often depending on your climate and how many miles you drive.I live in Arizona so the windblown sand tends to scour everything, even the paint.
There are other similar products besides Novus.Try doinga google for "scratch remover".
EZDUSIT
Texas_MGM Jan 31, 2008 08:44 PM
Brake fluid worked for me.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45";
urchinTracker();
TKemp Felony Feb 1, 2008 07:12 PM
i bought 1500 grit sandpaper and wetsanded them... then took rubbing compound and polished them out... i was very satisfied....
