Hello, New to forum, have a question right off the bat. Have 2004 Marauder that the shop told me i have a bad light control module. Now the stealer will not give me the part # cause they say they want me to buy it from them. It is against the law now they say. Does anyone know the part # to the module that is said to be under the pass side dash area.
from what I can find, it''s a dealer only part. nobody (parts houses) sells it.
Thank you Slymer, i will let you know if that is my problem also for thefuture.
good luck.
I've got an '04 MGM and the LCM has been labeled as "faulty" and it's around $300. I found a company in Tennessee that rebuilds them for $40+shipping. Look on Ebay motors for this "Lighting Control Module". The p/n on mine is:4W7T-13C788-BB
Good luck |
guys are we sure that it for sure is light control module? what are the symptoms,also is this a chronic thing?
I have an 03 Marauder and on a trip I lost my headlights, they would only come on if I pulled the stalk into high beam. After dealers installed new function and headlight switches headlights still did not work. I found an electrical wiring diagram at the local library and bypassed the LCM with a remote relay (For about $15). Now my lights work every time and I did not replace the LCM, which the dealer told me cost $500.
Does anyone have experience putting a blower on an 03 or 04 Marauder? I have the blower from a Terminator and would appreciate any advice.
It is a dealer part only unfortunately. getting the part number on the other hand can give you the option of having it rebuilt or finding one in your local Boneyard.
Terminator?
