-   Mariner (https://www.mercuryforum.com/forum/mariner-23/)
-   -   special message numbers for front end noi (https://www.mercuryforum.com/forum/mariner-23/special-message-numbers-frnt-end-noi-326/)
Lenny 10-24-2005 12:55 PM
2005 merc.mariner 2 wheel drive question.
a 702000 nvh other noise concearn/special message numbers;
18837 front end noise
18763 power steering noise
A SURGE IN POWER STEERING LINES/PUMP CAUSES A RATTLE IN FRONT END. What is being done for this if anything???
Lenny.Edited by: Lenny
Patrick 10-24-2005 03:11 PM
im afraid that i dont understand your post...
Lenny 10-25-2005 10:24 AM
Does anyone know what is being done for this problem?
These are special message numbers for this issue.
Lenny
Patrick 10-26-2005 04:19 PM
if a power steering surge is causing the lines to move enough to rattle, they are probably just tie-wrapping them against something..i used to work at a dealership, and youd be amazed at how many recalls are fixed with tie wraps..
Lenny 10-27-2005 11:56 AM
youv'e got to be freakin kiddin me.
Patrick 10-28-2005 05:26 PM
not at all..
i am trying to recall the specific recall, but when the tech would go to the parts window and ask for the recall kit for so and so number, it was LITERALLY a zip tie, in a plastic bag, and a razor blade with which to cut the loose end.
scheuer1 11-01-2005 10:50 AM
I assume you are talking about the dashboard message center. Your car is still under warranty so run it by the dealership, let them read the codes and have them fix it. The vehicle just came out this year and there are going to be bugs even though it is built on theFord Escape Platform.
Patrick 11-01-2005 04:52 PM
that is a good point.
Lenny 11-02-2005 11:37 AM
No. the numbers are from the dealership attention codes. The power steering line is hitting the fresh air duct going to alt. Hose starting to chaffeEdited by: Lenny
Patrick 11-02-2005 06:32 PM
but there is no TSBon it?
