special message numbers for front end noi
Old Oct 24, 2005 | 12:55 PM
Lenny's Avatar
2005 merc.mariner 2 wheel drive question.
a 702000 nvh other noise concearn/special message numbers;
18837 front end noise
18763 power steering noise
A SURGE IN POWER STEERING LINES/PUMP CAUSES A RATTLE IN FRONT END. What is being done for this if anything???
Lenny.Edited by: Lenny
Old Oct 24, 2005 | 03:11 PM
Patrick's Avatar
Administrator
im afraid that i dont understand your post...
Old Oct 25, 2005 | 10:24 AM
Lenny's Avatar
Does anyone know what is being done for this problem?
These are special message numbers for this issue.
Lenny
Old Oct 26, 2005 | 04:19 PM
Patrick's Avatar
Administrator
if a power steering surge is causing the lines to move enough to rattle, they are probably just tie-wrapping them against something..i used to work at a dealership, and youd be amazed at how many recalls are fixed with tie wraps..
Old Oct 27, 2005 | 11:56 AM
Lenny's Avatar
youv'e got to be freakin kiddin me.
Old Oct 28, 2005 | 05:26 PM
Patrick's Avatar
Administrator
not at all..
i am trying to recall the specific recall, but when the tech would go to the parts window and ask for the recall kit for so and so number, it was LITERALLY a zip tie, in a plastic bag, and a razor blade with which to cut the loose end.
Old Nov 1, 2005 | 10:50 AM
scheuer1's Avatar
I assume you are talking about the dashboard message center. Your car is still under warranty so run it by the dealership, let them read the codes and have them fix it. The vehicle just came out this year and there are going to be bugs even though it is built on theFord Escape Platform.
Old Nov 1, 2005 | 04:52 PM
Patrick's Avatar
Administrator
that is a good point.
Old Nov 2, 2005 | 11:37 AM
  #9
Lenny's Avatar
No. the numbers are from the dealership attention codes. The power steering line is hitting the fresh air duct going to alt. Hose starting to chaffeEdited by: Lenny
Old Nov 2, 2005 | 06:32 PM
  #10
Patrick's Avatar
Administrator
but there is no TSBon it?
