-   MF Help & Suggestion Center (https://www.mercuryforum.com/forum/mf-help-suggestion-center-25/)
-   -   Air suspension (https://www.mercuryforum.com/forum/mf-help-suggestion-center-25/air-suspension-10927/)
James Perrino Nov 30, 2019 04:08 PM
Air suspension
Hi there, I have a 2003 Mercury Grand Marquis. It has new airbags in the back for the suspension. However, recently the air compressor will work for a few days and then for a few days it will not work.. When it does work everything is fine and there are no leaks. What could be the problem?
95 MERC Dec 1, 2019 08:28 AM
Air Bags
Take it back to the shop that installed the "new" air bags to have it checked out.
https://cimg0.ibsrv.net/gimg/www.mer...eb75ecd6aa.jpg
Like No Other
James Perrino Dec 15, 2019 03:52 PM
it was in 2015 when the new system was put in. Could it be the level sensors? I changed the relay under the hood and changed the air compressor. It worked for a day after doing that but the problem started again. All this work I can do myself. I just want a push in the right direction. This was my parent's car. I've never been to a mechanic in my life. I fix everything myself. If I can't figure out the problem I will just install coils and be done with it ;)
