Change the forum's default away from displaying just the days posts
It drives me nuts that whenever I click on any forum category I get:
There have been no posts in the last 1 days in this forum. Try using the controls below to search for any older posts that may exist. with zero posts showing and I have to filter it every time. Then when you posts, most likely no one ever sees it anyways. I would believe that activity would be higher if the default was like 30 days or something like a normal (filtered) forum. Just my 2 cents....if you see this in time ;) |
| All times are GMT -5. The time now is 06:48 AM. |
