53 Monterey patch panels
I have a pretty rust free 53 Monterey that i am looking for a couple of patch panels for. I need panels or pieces for in FRONT of the REAR wheels, both sides have about a 8x12 area that i need to replace. The top and back of the rear fender opening are solid. I also need a trunk pan (someone drilled a hole in the trunk for an antenna, then removed the antenna and let it set outside for 10 years). I can find some patch panels, but not for these areas. Any suggestions as to where i might finds some? the car is really solid other than that.
Thanks!
Thanks!
