does anyone know the best way to connect seat belts to a 1960 monterey? i thought it came stock with seat belts, but under further investigation, i didn''t see any place in the middle of the seat to connect a seat belt for each side. i was wondering if anyone has put seat belts in a car similar to this before and could tell me how they did it, any help is appreciated.
I would guess just drill a hole, weld the nut to the outside and bolt down... or bolt down and then weld the nut to the floor. A three point harness will just require more drilling for the shoulder hooks.
the welding is optional, but does tend to help. |
ok, i was hoping there was some way to avoid having to drill, i thought maybe there was something already there to bolt into, but i guess not. okay, thanks. |
There may be something there to bolt to, you''ll have to lift the carpet and anything else in the way to find out first. you could cheat a little and bolt it down with the rear anchor of the seat (unless it''s a bench with bolts on JUST the outside points).
