| fixmiester |
Oct 10, 2023 05:51 AM |
06 Premier 4.6 L Oil Temp sensor wiring problem
Have wiring diagrams that show how the sensor connects to the PCM (gives pin numbers), but I don't have anything that shows the pin arrangement in the three plugs that connect to the PCM, so I can't ohm out the wiring harness to see if I have continuity leading to the oil temp sensor. Does anyone have info that correlates the pin numbers to the cable plugs connecting to the PCM? My schematics show wire colors, but I haven't seen the colors I'm looking for, so far. Would really appreciate any info you might have.
