2000 MM Turn Signal Issue
I have a turn signal issue on my 2000 Mountaineer.
So the problem is that when i push the lever down, the signal sometimesz blinks only once. When i play around with it for a while (turn lights on and whatnot) it tends to work at times. Fuses are good too, What do you guys think? Grounds issue? Bad switch? Let me know if anyone has the same issue and how they fixed it. |
| All times are GMT -5. The time now is 08:34 AM. |
