2000 Mountaineer
Old Oct 7, 2009 | 10:08 AM
pwt3d's Avatar
Default 2000 Mountaineer
My Truck has a grinding noise when I break coming from the front end driver side, i've had the ball joints, control arm, tie rod ends all replaced. The breaks and rotors were replaced in March. I've been to two different mechanics, first one thought it was the ball joint, and replaced it. Any other ideas? I only hear the sound when I begin to apply the break to slow down, once the break is applied fully to stop it goes away.
Old Oct 7, 2009 | 12:26 PM
conan312's Avatar
You should check your brakes (calipers, pad shims, bent or mis-installed wear sensor, bolts, etc.) to be sure everything is okay and not your culprit. Could be a bearing. The only time you ever hear it is when the brake is applied lightly?
Old Oct 8, 2009 | 09:37 AM
pwt3d's Avatar
yeah when I'm like on the highway and I apply it to slow down, I hear nothing, and I have no problems when I have slam on the breaks, its like when I gradually break to come to a stop, I hear it.
Old Oct 8, 2009 | 09:46 PM
in that case, it's probably just pad vibration. some brake pad shims and shim grease should sort that issue. If the brake pedal bucks at all while you're breaking, that means the rotors are warped and need to be turned or replaced.
bradshaw918
Mar 11, 2009 12:49 PM
data6326
Mar 11, 2009 12:21 PM
GorDog
Feb 10, 2009 04:07 PM
epepe
Nov 23, 2007 12:42 PM
alex32288
Apr 19, 2006 10:30 PM
