-   -   2000 Mountaineer Fog Light Issue!!!!! (https://www.mercuryforum.com/forum/mountaineer-17/2000-mountaineer-fog-light-issue-2804/)
data6326 Mar 11, 2009 12:13 PM
My fog lights don't work, I don't have good wiring of relay location diagram to work with, but I pulled the bulbs and the switch, and all that stuff is good so i'm thinking that the switch itself is not getting power, but i have no clue as to where the flipping relay and/or fuse for that function. Need help!!!!
Thank you!!!
slymer Mar 11, 2009 12:23 PM
for fuses, the manual "should" have the right info.
if you don't have it, go to www.motorcraftservice.com and click on owner guides on the left menu and enter your vehicle info. You should be able to get a pdf of any vehicle after 1996.
conan312 Mar 12, 2009 02:50 PM
You must invest in a test light. Very affordable and most helpful in your situation. Follow the juice.
