2000 mountaineer TravelNote light blink
Old Mar 8, 2009 | 04:38 PM
bradshaw918's Avatar
My TravelNote/Homelink transsceiver mounted on driver side sunvisor started blinking red and I noticed unit was not working correctly, I pulled fuse in an attempt to reset unit, and it worked correctly for a while, then started blinking again. Any suggestions, other than replacing unit?
Old Mar 11, 2009 | 12:49 PM
Check the voltage regulator to make sure that the proper voltage is being output. If that's ok, then it's probably an issue with the transceiver and it will need to be replaced.
Since resetting it seems to get it to work again, there's probably something else wrong, but it could have an intermittent fault internally in the control module. Definitely check all wires and such going to the unit for proper connection. If everything "looks" good, then it's probably a voltage problem or module problem.
Marquis03
Mar 22, 2023 10:12 AM
data6326
Mar 12, 2009 02:50 PM
data6326
Mar 11, 2009 12:21 PM
Cathy Kirkes
Jul 22, 2007 10:15 PM
Cathy Kirkes
Apr 19, 2007 08:00 AM
