-   -   2002 Mountaineer - Backup Sensor Problem (https://www.mercuryforum.com/forum/mountaineer-17/2002-mountaineer-backup-sensor-problem-1715/)
Stiltz79 Apr 24, 2008 04:02 PM
My backup sensor stopped working. The off light just stays on all the time. When I press the button to turn the sensorss on it just shuts back off. I'm not sure where the fuse is or the relay. I cleaned off the sensors and the little gap around the sensor is clean also. If anyone has any ideas that would be great.
Also looking for a good place to get some rims for my truck. Any suggestions for reasonable priced places is greatly appreciated.
Mike
Edited by: Stiltz79
graphix1998 Jan 7, 2009 02:14 AM
did you find any help...? Mine started doing this around Christmas.
Thanks
slymer Jan 7, 2009 04:40 PM
sounds like it may be a controller issue. if one of the sensors has gone bad, been disconnected/damaged, it may not work. You may have to get a dealer to check this one out since this is still a relatively new technology and there''s not near as much info on it as there is with other things (like cruise control).
