2002 Mountaineer traction issues
Old Feb 25, 2009 | 02:34 PM
keenan's Avatar
Hi!
I''m new here and new to Mercury vehicles. Within the past year, we have purchased two Mountaineers, a 2002 and a 2005 Premier, replacing Jeep Grand Cherokee Limiteds with over 150K miles on each of them. I''d like to use the 2002 for hunting and light off-roading, gravel/dirt roads, but I''m concerned that the AWD system won''t offer enough traction in mud or snow. Is it possible to install a locker unit in the rear differential and, if so, will it work with this vehicle''s AWD transfer case?
Thanks in advance for your help and advise.
Old Feb 26, 2009 | 07:46 PM
I''d figure that if it has open difs, then it should, but if the difs are computer controlled clutchy types for traction control, then there''s no need. I do know that the mountaineers do not perform as well as jeeps do off-road (from people I know that have driven them) but once you know the capabilities, you learn to avoid the few areas that get you in trouble. the mercs aren''t far behind the jeeps, but aren''t quite as good off-road.
My advise would be to talk to a dealer to get the exact specs on the diffs and then look around and see if there are lockers available for your model.
Old Feb 28, 2009 | 01:05 AM
conan312's Avatar
I personally would feel confident your Merc''''s full time AWD off-road. But like Slymer said it is no Jeep. Ground clearance and grade incline/decline for exmple. Maybe a good set of mud tires would be cheaper? Doesn''t it have IFS/IRS?Edited by: conan312
Old Feb 28, 2009 | 09:03 AM
keenan's Avatar
What is IFS/IRS?
Jeff
Old Mar 1, 2009 | 01:40 AM
conan312's Avatar
Independent front and/or rear suspension. Sorry for the acronymns.
Cougirl
Oct 5, 2008 05:37 AM
hhunni08
Jan 18, 2008 11:27 AM
gregv
Oct 21, 2007 08:54 AM
92Mercury
Aug 30, 2007 07:43 PM
vasurveyor
Dec 21, 2005 01:25 AM
