2003 mountaineer not thing but problems
Old Aug 7, 2009 | 04:14 PM
MADMIKE's Avatar
Default 2003 mountaineer not thing but problems
I have had nothing but problems with my M M. (M M = mercury mountaineer ). I joined this forum to leave out some steam. Does any one else feel like this. My new problem is my torque converter is low in fluid. Is there a way to full it, with out taking down the transmission? And what is the deal with no dipstick. If i had a dipstick I could have checked the level and maybe this would not have happened. He should be shot!!!! Over and over again. Can some help me plleeaassse!!!!! Drop me an E-mail mike_mirta@yahoo.com
Old Aug 8, 2009 | 09:22 AM
conan312's Avatar
I'm not sure why they built some of the 'Neer's w/o dipsticks. I've never seen but the complaints are many. If the converter is low then the trans is low. If you look there is probably a service bolt (like a 3/8 rachet plug bolt on the differential in a RWD car) for you to check and add fluid if it is a truely sealed unit. Now on a different note, who should be shot over and over again? The trans designer?
Old Aug 9, 2009 | 12:15 PM
MADMIKE's Avatar
The design engineer! The drain plug was a good idea. I checked the fluid level using the level plug. The trans fluid poured out. From my understanding if the level is right you should only get a drop or two. But it poured out. This tell me that the fluid is not circulating. It's going into the tran but not back into the converter. Or not enough.
Old Aug 9, 2009 | 05:00 PM
yup. time for a rebuild. could be a clogged filter, could be a bad pump. either way, stuff isn't being lubricated right and you'll probably have to replace that torque converter and clutch plates. filter and fluid are standard on a rebuild. Expect to pay at least a grand for the repair. depending on what's been burnt, it could be up to 2 grand.
Old Aug 11, 2009 | 04:24 AM
conan312's Avatar
If the 'Neer shifted and worked okay before this and you are familiar with large drivetrain parts, seperate it and change the converter before you spend a small fortune on a rebuild. Just don't forget to fill the converter before install. You might even consider a junkyard trans if $$$$ is an issue. Good luck. Mileage?
214shaft
Jan 3, 2011 11:21 PM
MrDeluxe
Nov 19, 2008 04:37 PM
marquezjr
Nov 6, 2008 02:54 AM
mishalah
Nov 7, 2006 07:50 AM
mishalah
Oct 21, 2006 12:31 AM
