-   -   2006 Mountaineer stalling (https://www.mercuryforum.com/forum/mountaineer-17/2006-mountaineer-stalling-8166/)
treasures4u1 04-17-2016 08:15 AM
My engine light came on and error code is P0401 Exhaust EGR Flow Insufficient. The car is misfiring and will actually quit as I am driving down the road. I have done some research and have come up with that maybe I need to replace the GSR valve? Can anyone tell me if that is so?
Thanks
conan312 05-10-2016 08:07 AM
It seems to me that the code Or the EGR valve does not match the symptoms you are experiencing with the vehicle itself. A frozen EGR can cause pinging and detonation. Misfiring is not a symptom of a bad EGR. The vehicle stalling definitely not. The only time I've had a the vehicle's engine cut out while in the act of driving was from a faulty crank sensor. A lot of the symptoms sound electrical to me.
leftoverture 05-21-2016 06:26 PM
I would agree with Conan. Sounds like a professional diagnosis might be in order.
Jonathan Scott Brodeur 01-15-2019 02:16 PM
Thanks
did you ever fix this problem? i’m having the exact same problem. ive replaced egr, 02 sensors, coil pack, spark plugs and wire set and pcv. i think i’ve got a wire chafing somewhere
ronaledsmith 04-22-2019 03:24 PM
I've been faced the same victim around 5 months ago.:rolleyes:
It was really awkward.
