2010 Mountaineer No brake lights. Shifter lock in park
Hi folks. Shifter intermittent lock in park.If I keep tapping the brake pedal it will work. When not working the brake lights don't work. Possible brake light switch or relay. Will be working on it tomorrow. What would you consider the best place to start. Thank you UPDATE did change brake light switch but no go. All other lights do work but not brakes.
